piratecoach
- Sep 19, 2006
- 4
I am designing a reinforced concrete wall. I would like to design it to ensure it may withstand the maximum operating equipment load behind the wall. The area is paved behind the wall. ASCE code recommends a minimum of 250 pcf for tractor trailer and fire lanes, but how do I analyze a load for a loader having an operating weight of 100,000 pounds?
Is it reasonable to view the pavement as bearing the weight of the loader and treating it as a surcharge load, using the area between the center of the tires? Example, if the loader has an operating wt of 100,000 lbs, a 15' long wheel base and 12' wide axle length between tires, would it be unreasonable to call this a 555 psf surcharge behind the wall? My gut feeling is this is not an acceptable design procedure.
