This is a task for codemakers. They need not only to average between lots of measures between many stations, but also determine the expected wind velocities (and changes of velocities) that assure you won't surpass a given probability of the proposed forces as determined by the code will be exceeded say with a 5% of chances in a big span of time; if timespan is to be allowed different, say for 1, 2, 5, 10, 25, 75 and 100 years.
Hence, taking a reductionist approach in which only wind velocities are counted on, you will need first to identify a distribution of the measured wind velocities that matches the best the data, and then use such distribution to ascertain which top velocity is not exceeded but in 5% of the measures. You may also do this just over the data, or their average for representative points for the zone or height etc. You have then determined a characteristic wind speed and then derive with the usual formulas the wind forces.
