Determine Units inside a rule
morauski
Automotive
been working with catia about six months. just getting started into creating rules and i have a need to know what the current units are within the rule. is there a way to find out what the current units (mm or in) is? I need to format a catalog value with only mm values
Which sort of rules do you mean? rules from KWA or the rules which you can get with the fog-icon?
CEROG
If I recollect right, if you don't have a unit to numerical value it will be counted in meters and parameters of length, angle.. type will be according to setting
it is from the kwa side of things.
if the user's units for length is set to mm then all is well; if they select dia= change it then the current rule looks at the value converts it to a string and changes the catalog entry from say D40 L300 to D30 L300 but if it is set to inches then it ends up looking like D1 L300
I haven't found the functions/procedures or whatever you call them in Catia
i would think that something like IsMetric() would exist but don't know where to really look
After experimenting with the string options it turns out that when you convert a parameter to a string it also includes the units. so i was able to check the string for the units and then format the required string based on the test.
However, if there is an easier way i would still like to know about it.
