CuriousElectron
Now days with a smart relay, can a single-phase ground fault be detected with digital relays without utilizing the typical ground fault scheme utilizing residual/zero-sequence CTs? If there is a single ground fault, there would be zero current flow in one of the phases. The relay will detect this single phasing event and will trip.
It sounds like the relay can be programmed to calculate this single ground fault on ungrounded system without elaborate zero-sequence CT/VT schemes.
Am I right on this thinking?
Thanks,
EE
Thanks,
EE
