Martahue
- Sep 7, 2021
- 2
I have been tasked with modifying a standard median barrier for offset road elevations to increase the height of the offset.
The height of retained roadway is approximately 5' with a 2'-8" crash barrier on top.
The contractor has asked for the retaining wall to have no toe so that the wall can be directly adjacent to drainage structures.
My question is about the crash loading. I have looked at standards from several states and I cannot find any state that seems to have actually designed their barrier to resist overturning at the extreme event II condition for the crash loading. However, for our modification, we need to meet all of the stability requirements for this load case.
Without increasing my footing to an unreasonable length, what are some ways that I can reduce the crash loading transferred to my footing? (I am distributing the moment to the footing over a max of 20' for location of construction joints, but my moment per foot is still high).
I know that MSE walls have barriers mounted on moment slabs which resist the overturning and then the shear is transferred into the top few rows of tie straps. If did something similar, then I could at least lower my crash force by the height of the barrier. Could I also consider some of the shear to be taken by the friction from the moment slab to the soil?
I can provide some sketches if this is not a clear question. I apologize as this is my first post.
Thank you in advance for any suggestions
