sshep
Chemical
- Feb 3, 2003
- 761
Friends,
A replacement vertical thermosyphon reboiler in one of our plants suffers from instability and heat transfer limitations. On the theory that there is no liquid circulation (failure to thermosyphon), we are injecting some steam below the bottom tubesheet which has helped and we are surviving. The is the second such rebolier performance failure that I have seen which were both characterized by: 1) being a vertical thermosyphon variable area type on the shell (steam) side, and 2) the process is an aqueous & hydrocarbon mix.
In both cases the towers are at atmospheric pressure. The systems were involving MEK-water (this time), and C11 hydrocarbons-water (last time).
Can you tell me:
a) How does one normally design a reboiler for the uncommon situation of two liquid phases?
b) Can you think of a mechanism that would cause a failure to thermosyphon due to two liquid phases?
The first time I thought there was a reboiler return head design problem (cone type with high lift), but in the most recent case there is nothing unusual. Although this was a replacement, I can see that the very similar old one also struggled. Maybe new tubes are making the old problem even worse.
Any ideas could be great.
best wishes always,
Sean Shepherd
Can you tell me:
best wishes always,
Sean Shepherd
