Shylanel:
A capstan to me means three wraps of the rope or cable around the capstan so it can be used to pull the load or lift the sail. And, I’ll bet that’s not what you mean, so start there, and explain. What you see as a capstan, we can’t even imagine, and we can’t see it from here. What applies and how is it applied, on both the cable pulling tension and the torsion/twisting action, that’s 2. Is this a cable pulling operation from floor to floor, that’s 3. What kind of cable is this, fiber optic, computer cable, how’s it made, is it a twisted/layed up cable which twists a bit by the nature of its construction, when you pull it over the capstan, that’s 6, 7, 8 and 9? There aren’t many simple answers to complex problems. And, if you think this is a simple problem with all the variable you have already laid out, and the limitations you have put on it; that just shows that you don’t understand your own problem very well, and sure aren’t describing it very well. You can weld some of these, but they have to be taken apart when they reach the upper fl., that just doesn’t wash. Can you lose or gain wire length in the separation? The connector must be smaller than the wire dia., that’s a tall order and a dream. Are some wires in the cable splices and others not, that’s 10? I’d wrap the cable in electrician’s tape, and unwrap it at the upper fl. Would something like the old Chinese finger lock/puzzle work? There are cable pullers like that on the market. We don’t even know what size the cable and individual wires are, or what size duct you are fishing this through.
MintJ. is right on the money above. So many of the questions we get here are so pie-in-sky that the OP’er. can’t begin to describe them sufficiently to illicit some meaningful discussion. We are all guessing, wasting our time, and getting nowhere; and if by chance someone guesses crazy enough to find a solution, they get a shout-out. You’ve got several smart people posting on this thread, and your just not getting through to them, and that’s not for their lack of effort. These problems, on this forum, are a real pain in the arss, because we have to ask so many questions before we tease another important fact out of you, and you didn’t even know it was important. You haven’t described what it is or how it works well enough so we can ask some meaningful questions, we’re all just fishin in the dark. These discussions would be so much more productive if we could see some properly proportioned sketches, with dimensions, loads, etc. and some photos of the system, so we knew what you where dealing with, what your idea of a capstan was. If we could be standing together looking at the problem, this give-n-take or exchange of ideas would flow much better. And, if the OP’er. gives out important info. in drib-n-drabs it just frustrates the hell out of a bunch of smart people trying to be helpful.
Shylanel.... this is not specifically directed only at you, it just happened to finally get posted on your thread. I am not trying to pile on here. This seems to be all too common an occurrence on these fora, the issue of ill defined questions or problems. You haven’t presented a simple problem, and you certainly have not presented it well. Again, WE CAN’T SEE IT FROM HERE.
Good Luck
