I wonder if any of you can throw some light on a question :
In British Standard for Reinforced Concrete Design, the Code asks for the continuous beams to be designed for bending moment values at centre line at support. Although there is guidance on the redistribution of support moment, it is the value at the centre line of support that has to be allowed for in the beam design.
But the section on design of bases says that the critical section for bases is at the face of support.
Why should there be a difference in which value to take for design? I guess that the ACI and Eurocode are similar in their reccommendations, but will appreciate if you have any comments.
