Design standards for Crane 3
ccking1
CA
Hi!
I've to modify an existing over head crane made of 2 girders. I'd like to know what standard do apply to this situation. I'm from Canada, and some canadian or international standards would be perfect!
Thanks!
CSA S16 and likely some labour or hoisting act requirements applicable to the province. The CISC has an excellent publication on cranes and the AISC has a really good spreadsheet.
Dik
For the crane itself, you may want to check out CMAA Report # 70. Not sure if that is acceptable in Canada or if that is only U.S. applicable.
The crane runway beams is another matter which should fall into normal steel design specifications (AISC if you're south of the river) with the applicable fatigue requirements, etc.
In Canada, you might want to look into CSA Standard B167. There is a 1964 version of this standard that covers design and testing aspects. Then there is the 1996 version that covers maintenance and inspection. The 1996 version preface notes that this "newer" version is to coexist with the 1964 version until such time as that 1964 version is updated as CSA Z202. The last time I checked (+/- 6 months ago), CSA Z202 was as yet unwritten (10 years after it was mentioned!).
Depending on your jurisdiction's requirements, the CMAA70 spec is quite likely applicable. Can you contact the crane manufacturer to find out what standard was used for the crane's design & fabrication?
Cheers,
CanuckMiner
Thanks,
I've just checked CSA B167, but seems it threats only the maintenance and inspection of cranes.
Does CMAA-70 give the combinaisons, safety criteria en deflexions required to design the girder and trolleys. The existing hoist will be kept. Unfortunately, I cant contact the manufacturer because he does'nt exist anymore.
ccking1,
As I said, CSA B167-1964 covers design. You may have to call CSA to get a copy as I don't see it listed on their webstore. We have an old, tattered hard copy here at the office that is probably older than I am.
In my industry (underground mining), the OHSA and mine regulations refers to B167-1964; however, mine inspectors have accepted CMAA standards (#70 for multi-girder top running cranes and #74 for single girder cranes). Check with your local jurisdiction to see what is required/acceptable.
Yes, CMAA #70 does give the load combinations and deflections, etc. It is a very good design document and is most likely what you are looking for.
Cheers,
CanuckMiner
This isn't a standard but as a text on cranes and loading the book by Shapiro, Shapiro and Shapiro is very good. It likely has the necessary code references in too.
Qshake
[pipe]
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
SlideRuleEra,
I've heard the Whiting handbook mentioned many times over the years but never had a copy myself. Having just glanced over it I can see that it has some interesting information.
Thanks,
-Mike
I've just glanced over it myself and there's some very interesting stuff in there. But it's old material, older than I am! Is there an earlier version of this handbook.
Thanks a lot for the digitized jod you've done.
mrMikee & ccking1 - Thanks for your comments. I also have the Second Edition (1955), can digitize it too, if there is a need. Not too much difference between the two - both were compiled by the same person, H. G. Greiner. First Edition came out in 1930... don't have that one.
Have heard that there is a Fourth Edition from the 1970's and perhaps? a Fifth Edition.
[idea]
You might consider subcontracting the whole deal to your local crane manufacturer...
Mike Halloran
Pembroke Pines, FL, USA
