Hey,
I am wondering if anyone has a reference to a guide on metal (machined) ribs design in different parts for making it stiffer. I can think of some questions:
1. In which side I have to put the ribs? In the surface side that is in compression or tension? And why?
2. What should be the rib width and height relatively to the wall thickness?
3. What should be the distance between the ribs?
4. What is the right pattern for the ribs? Only Longitudinal or a combination of several directions?
I have a case of a vacuum cylindrical tank and I wonder in which side to add the ribs? On the outside surface that undergo compression or on the inner surface that undergo tension?
I am sure there are some good practice advices you can share with me
