Chandan321
Hi All,
I am trying to design a base plate with axial load and bending moment. I have different cases of eccentricity: L/6 < e < L/2, L/2 < e < L and e > L.
I found that different references have different methods of designing it:
1) Blodgett uses the assumption of plane section remains plane and solves a cubic equation of forces and strains to get: concrete bearing stress, bearing length and anchor bolt tension.
2) AISC Design Guide 1 says that the above assumption may not be correct as the base plate and concrete may not be in contact everywhere. The anchor bolt tension and concrete bearing stress are independent of each other. The Design guide assumes that the bearing stress will reach max allowable value. The guide then finds the bearing length from summation of moments, and then the anchor bolt tension from summation of forces.
Each of the above methods yield different results. I want your suggestion as to what method is generally used in the industry practices for designing base plate with axial load and bending moment.
Thanks for your time.
