I'm thinking about using a ball bearing in an application where the bearing would run immersed in fresh pond water. I'd like to hear from anyone who has a similar application: what are the load conditions, bearing material (stainless, ceramic, etc?), type of water, and the real-world vs. calculated life.
In my case, shaft speed is 1200rpm and the load would be 100lb radial. Bearing will be in the 6018 to 6020 range. My basic L10 estimates are very high due to the low load which means with contamination and material adjustments this may be feasible.
