I believe that the resonant frequencies of a horn are dependent upon the lenght, and not the width, flare etc. Those other parameters affect the timbre, but not the pitch.
I know that the harmonic series of tones which can be formed on a horn will be separated by an octave, then a fifth, then a fourth, then a major third, then a minor third etc. This corresponds to factor of 2, then 3/2, then 4/3, then 5/4 etc. From this pattern it is evident that it is a series of tones of frequency f, 1f, 2f, 3f, 4f etc where f is the fundamental frequency.
I believe that the fundamental frequency is given as f = v/L where v is speed of sound in air and L is length of horn. 2nd harmonic would be v/(L/2), 3rd harmonic v/(L/3). These are frequencies at which the length of the horn is an integer multiple of the wavelength.
I'm going from memory and a little rusty, so please double check it.
