Question: I work on an enviromental remediation project where we need to remove a section of a sewer line due to contamination. What we need to do, is order the correct rated pump to handle the flow rate of liquids that would normally pass through this line from the upgadient areas. There are several upgradient lines that connect to this one and the load is from runoff water only. Is there a nice rule of thumb for something like this or do you need to do some Q=VA calcs. I dont do this sort of thing much. Thanks for any help you can offer.
