Kris the Engineer
I am currently involved in a project that will be a 5 story building that will be made of premanufactured containers (similar to shipping containers) that will be custom built in china and shipped over and then stacked to make the building that will be located in California. I am having the hardest time finding any relevant information for the lateral design of the building regarding the seismic parameters and the allowable load for the shear wall. The containers will be built with steel beams along the top and bottom along with steel posts at the corners and for interior bearing points. The walls/lateral system will be corrugated panels that will be welded to the top and bottom beams.
Has anyone used this type of system in the past or have any reference material on the seismic design parameters for the corrugated metal panels? For the allowable strength I was going to look at an equivalent Verco section since they have an allowable diaphragm load. Please let me know your thoughts and if I am going down the right path.
thanks.
thanks.
