I'm looking for some help with a product I'm designing.
It's a marking device that has a valve at the tip. It is filled with alcohol based liquid and when the tip (see green below) is pressed the liquid flows.
Pretty much I'm reverse engineering a whiteout pen. I want to learn more about this type of valve but I'm not 100% sure what its called. I guess its a check valve but is there a specific term I should be researching. I want to learn more about the sealing area and how they should match up to make a good seal.
Another issue I have is the size of these components. The smallest size is .02" dia and that is .250" long and the female part needs special tooling to machine this profile. I'm thinking about increasing the size but again not 100% confident in my knowledge of this type of valve.
Please let me know any suggestions or need anything clarified
