(Design) formulae for reducers - contraction angles etc.
XL83NL
3,109
Does anyone knows of any publication, design info sheet or such (I couldn't find it in any ASME code/standard anywhere),
where I can find the (physical) design, with respect to dimensions and angles, for a (concentric) reducer?
I'm having a hard time defining the K-factor as I don't know several parameters like the exact angle of contraction, etc.
I do know the overall dimensions, and inside radii, but there's more info required for determining the K-factor.
Also, are there any limits as to how fast/sharp the contraction/reduction may occur, or how smoothened it should start?
Thanks in advance.
Anyone having some suggestions?
You can use table 7-4 (Loss Coefficients for Expansions and Contractions) chapter 7- page 217 from "Chemical engineering fluid mechanics – second edition , Revised and Expanded" by Ron Darby.
There is so much variation between different manaufacturers, and even within the tolerances from one manufacturer, that it is impossible to be accurate with your K-factors. All you can do is choose a conservative average and apply a reasonable safety factor.
For some indication of the variablilty in the real world have a look at
Then you can laugh when people argue over whether the K-factor of a fitting is actually 0.26 or 0.28.
Katmar Software - Engineering & Risk Analysis Software
"An undefined problem has an infinite number of solutions"
Thanks ione, but you first post was already overcome in my original post. I will see if i can find a copy of Darby's book, it may be useful.
Thanks katmar, for the useful link. As you implied, I already thought it's almost impossible to define 'the' K-factor of a fitting. Knowing the range it may operate in at least gives a better engineering approach.
