helfreco
- Feb 15, 2011
- 21
I am trying to design an end-plate beam splice with the same detail as DG16 Figure 1-3(a). However, the splice also needs to carry a moment in the weak direction of the beam, so I have biaxial bending.
I am OK using Part 7 of the SCM manual to calculate bolt loads, so I am not concerned about figuring the bolt loads.
My issue is the end plate.
The equation for determining the end plate thickness in DG16 (either 2-7 or 2-9) is based on the no pry moment and the yield line mechanism. It does not seem that these equations would lend themselves to accounting for biaxial bending.
Does anyone know of a reference to determine the end plate thickness for a splice in biaxial bending?
