Yield-Line analysis by AISC's Carlo Lini ==> using SketchUp 4
Ingenuity
In the Feb 2019 issue of AISC's Modern Steel Construction magazine, Carlo Lini (AISC's director of technical assistance) has a good article in "steelwise" segment on yield-line analysis and how to determine flexural limit states.
The article link is here: Link on pages 17-19, or see the attached PDF.
A unique approach Carlo uses is using SketchUp to displace/rotate the yield-line and determine the rotations. A tutorial video is here: [link aisc.org/yieldvid]Link[/url]
 https://files.engineering.com/getfile.aspx?folder=17485365-4f59-45e7-a1aa-17713ff5c00d&file=YIELD-LINE_ANALYSIS_-_CARLO_LINI_-_Modern_Steel_Construction_-_February_2019.pdf
Thanks for posting, I can see this being damn handy as a design (or checking) tool for those cases that don't meet any published or easily derived solutions.
Still involves picking a valid or critical mechanism, but I can see it being a good way to visualise whether you have a mechanism or not so you don't miss any of those yieldlines!
For what it's worth, I think Carlo's sketch up solution may be more accurate than the formulas. The Formulas, I believe assume an infinitely thin web, whereas he sketches it out to his exact geometry.
Agent666: You are welcome. Indeed, a very handy tool.
JoshPlum: Good point on the thin web assumption vs Carlo taking into account the web/flange thickness geometry.
AISC has some great technical info - Engineering Journal, Modern Steel, their Night School series, Youtube channel etc.
