PlannerTom
We are at the beginning of route planning and a cost estimate for some developing areas in the Middle East that are in need of fresh water. I am trying to assess the pros and cons of installation of multiple 1-meter diameter surface-laid FRP water lines vice 3-meter surface-laid or buried lines over two routes, one of 850 km with a rise and fall of more than 1,000 meters and the second route of 1,000 km across a desert plain.
Our goal is to distribute 2 BCM (billion cubic meters) of water per year from each of two sites (4 BCM total), growing to four water source areas over the next 10 years. Route Number One would release water to consumers National Water Authorities at three points along the route, and terminate in mostly agricultural uses. Route Number Two will have smaller users at approximately every 100 kilometers and terminate in a large urban area where it will be linked with Route Number One.
Does anyone have some lessons learned on this type of work or with these diameter lines for those distances in the Middle East? What did your final costs per installed kilometer of water pipe cost? Would you have run multiple lines if you could do it again?
Thank you for any tips or advice you have. This project is far from being locked in. If approved, it will bring water to some low-cost areas that really need the water badly. Our success will depend on our keeping both the initial capital investment and O&M costs down.
