Mar 6, 2002 #1 TonyWright Chemical Joined Mar 6, 2002 Messages 1 Location CA I am purchasing two 8000 USG Xlinked PE chemical storage tanks and wonder if there is an approprate design code which should be specified? Thanks Tony
Mar 7, 2002 #2 MJCronin Mechanical Joined Apr 9, 2001 Messages 5,102 Location US Tony.. I do not believe that a design code exists for small PE tanks, similar to an API design code for metallic tanks (API-650, for example) Material standards for PE, of course, do exist.... PE tanks are purchased based on the vendor's rep and, sometimes certified by testing. This has only been my experience.....and I assume you are talking about USA Design Codes MJC Upvote 0 Downvote
Apr 12, 2003 #3 TheTankman Mechanical Joined Apr 11, 2003 Messages 4 Location US Design code for PE storage tanks is ASTM D1998-97. All of our tanks are manuf to this ASTM; both crosslinked polyethylene and linear poly. Our spec for single wall tanks is online at http://www.kefco.com/KEFSpec.htmlOur spec for double wall tank ass'ys is also online http://www.kefco.com/uptspec.html A link to the ASTM specification is also online at http://www.kefco.com a submenu of Technical Papers. Upvote 0 Downvote
