Blackdagger
- May 29, 2007
- 1
Using PLC for the water flow with respect to timing is not much of a problem. The problem for me now is the extra parts of the design. How am i supposed to integrate music and lights into the flow of water and to combine it with the timing of the water which uses PLC. Can that be done using PLC or should i use other programming languages. Basically i just need a brief explanation on how do i integrate music and lighting for the water flow with timing using PLC.
