descaling stainless hot rolled bar 1
mcguire
Materials
Flat-rolled stainless producers shot blast hot-rolled stainless plate and sheet coils before pickling to loosen the embedded-type scale which is hard to pickle off. What do bar producers do to break up the hot mill scale before anneal and pickle?
Michael McGuire
ASM HANDBOOK Volume 1 describes several conditions for stainless steel bar finishing:
Hot worked only: [1] scale not removed (except for spot conditioning), [2] rough turned, [3] blast cleaned
Annealed or otherwise heat treated: [1] scale not removed, [2] rough turned, [3] pickled or blast cleaned & pickled, [4] cold drawn or cold rolled, [5] centerless ground, [6] polished
Carpenter mills the surface of larger section square bars in order to remove the scale from hot-rolling.
