Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
UW-15(c) said:(c) The allowable stress values for groove and fillet welds in percentages of stress values for the vessel material, which are used with UG-41 calculations, are as follows:
(1) groove‐weld tension, 74%
(2) groove‐weld shear, 60%
(3) fillet‐weld shear, 49%
NOTE:These values are obtained by combining the following factors: 87.5% for combined end and side loading, 80% for shear strength, and the applicable joint efficiency factors.
VIII-80-29 said:Question: In UW-18(d), what does the 55% joint efficiency factor represent when calculating the allowable load on a fillet weld?
Reply: The 55% joint efficiency factor includes the conversion of the leg length of the fillet weld to the throat length (0.707), and the conversion of the tensile strength to the shear strength (0.8); therefore, no additional reduction need be taken in calculating the allowable load by computing the weld area.
VIII-80-100 said:Question(2): If the weld metal stress values specified in UW-15 apply to nozzles and reinforcement, in what cases does the stress value specified in UW-18(d) apply?
Reply(2): UW-15 is strictly for the reinforcing load-carrying paths of nozzles where UW-18 is for fillet welds which may not necessarily be around a nozzle. The values in UW-15(b) are 7/8 times the values in UW-18(d) to account for the combined end and side loadings. That is, 0.55 x 7/8 = 0.49.
VIII-1-95-42 said:Question: The Note in UW-15(c) of Section VIII, Division 1 says the 49% factor for fillet welds in shear is the product of 87.5% times 80% for shear strength times the "joint efficiency factor." Is this "joint efficiency factor" the same as the joint efficiency factor given in Table UW-12 (0.45 for single fillet welds)?
Reply: No, the joint efficiencies given in Table UW-12 apply only to the weld types defined in Table UW-12.
The Note 2 has been shifted to UG-23(g) in the latest codes. So, where you don't have ideal constrained shear, the efficiency needs to be less than 0.80, hence 0.45 for the lap joint. Still no answer as to how 0.80 is reduced to 0.45.VIII-1-95-39 said:Question: For UCS-23 material, General Note (b) to Table IA in Section II, Part D allows the shear stress in restricted members to be 0.8 times the value permitted in the Table. Does Section VIII, Division 1 specify the allowable shear stress in a member that is not restricted?
Reply: No, see U-2(g).
As clear as mud.VIII-1-83-11 said:Question (2): In Section VIII, Division 1, construction, for a shell and head attached by a single, full fillet lap joint without plug welds for attaching shells and heads not over 5/8 in. thick, how is the joint efficiency of 0.45 from Table UW-12, column (c), applied?
Reply (2): For calculating the circumferential stress in the seamless shell, UG-27(c)(1) is used with E = 1.0, but with stress used in the formula equal to 80% of the allowable stress from the tables.
For calculating the longitudinal stress in the seamless shell, UG-27(c)(2) is used with E = 0.45, but with the stress used in the formula equal to the allowable stress from the tables.
