Alexander87
Geotechnical
Hey Guys,
I'm looking at construction of a new MSE wall to support a proposed roadway embankment, so far I've determined that I need to remove and replace existing soft clay soils to satisfy bearing requirements for the wall, however the depth of this clay is on the order of 15 feet before we hit medium-dense sand and we do not want to propose removing the entire clay stratum if it isn't necessary. Unfortunately the depth of my experience as a junior engineer is limited to hand-waving for small spread footings, where engineering judgement allowed us to assume a general R&R on the order of 5 feet was appropriate.
I was thinking if we use pressure bulbs to assume a depth where new stress is on the order of 10% of current stresses then that would be OK, but with such a large embankment width that would essentially be the entire layer. Is that thinking too conservative?
Thanks!
Thanks!
