density of petroleum products 1
josy2020
Chemical
I am looking for an algorythm or an equation which i can use to convert density of petroleum products from physical temperature to 15oC.
Any help will be most welcome
"Petroleum Products" is such a messy term. Trying to convert crude from one temperature to another has to assume a staggering number of things about latent heats and boiling points. A stream that is liquid at -20°C is going to be very different at 15°C. Stuff that is a subcooled liquid at the first temperature may be a superheated gas at the second. Kinda changes density a mite. For a single-component liquid, you can use the bulk modulus to estimate at density at a theoretical temperature, but when you get a mix of Mother Nature's liquids it gets a touch more than complex.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
There are waxy fractions solid at ambient temperatures. Nevertheless, have a look at thread491-82117 and thread481-97175 for more comments.
