demineralized water seal plan
gilus02
IR
Hi
What is you idea for a seal plan for a demineralized water pump?
As the main fluid is corrosive do you recommend it for flushing?
The main flow at most could do heat removal for us, what about lubricant? We have to use an external fluid for lubrication purpose?
Thanks;
I am not aware of any outside flush which will be acceptable in demin water. We use Plan 11 if cold and Plan 23 if hot.
Johnny Pellin
