i need rewind data for a 3-phase delta radial arm saw motor, delta saw # 424-02-131-00-11, 20 slots, # of turn, wire size, how many wires in hand, & span.thanks for any help you can give
donf13:- if you send us the core length ,bore dia, tooth width, and back iron measurements (in mm) along with no of rotor slots, stator slots, volts and hz. we can design you a winding.
kind regds
