deleting blocks
Firerunner
49
Is there a way to delete a group of blocks out of a bigger group of blocks.
Ex. I have about 60 different blocks on the same layer and invaring amounts. I need to delete all instances of a specific block.
Can this be done without scanning the whole drawing and manually picking them??
type this: erase [space bar] (ssx) [space bar] [space bar] B [space bar] type your block name, etc...
IFR does that command of yours erase or delete the block as inquired?
if you type erase first, it erases. If you type move first, it moves. Erase and Delete are the same thing. (SSX) is just a way of selecting object groups.
