I believe the sweetening step, if required, should be the first step - followed by the dehydration step, especially if the sweetening is done using an aqueous amine solution. DEA and amine are mentioned. What is left out is that any amine solution is an aqueous medium and, as such, imparts water vapor pressure to the exit product gas out of the top of the absorber. This product gas, of course is saturated with the liquid with which it is in intimate contact at the top of the absorber - which is water and amine. This is why it does not make good sense to dehydrate before submitting the same gas to an aqueous solution absorption system. One would have to dehydrate again after the absorption because of the subsequent water pick-up.
Art Montemayor
Spring, TX
