Deflection of simply supported curved beams
KenStructural
HK
can you give me some reference on how to compute for the deflection of simply supported curved beam.
You need to provide more information. On what you have given us, the beam collapses, it rotates about the ends.
Michael.
Timing has a lot to do with the outcome of a rain dance.
For a simple beam, moment area theorems work well. Curvature can be approximated by using finite straight sections.
BA
Guys, I still don't understand a simply supported curved beam. If modeled as such you get singularity, if you try to build it, it rotates about the hinges.
Michael.
I assume the beam is arched, paddingtongreen. That is the only way the question makes sense.
BA
Or the beam has a continuous moment connection to the deck not to the support.
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
If the beam is curved (as in lateral sweep), simple supports won't work. If arched, as noted by BAretired, it would work.
As noted, we need more info.
