Oops, I meant to say 0.007" deflection with a Ø5.5" diameter section not 0.0007. But I calculated using case 3 in the Machinery's handbook a max deflection of 0.01659" for a shaft of uniform thickness of Ø4.438" at the same location you said desertfox (18.39157"
from the left end (x=0). Basically the load point is x=20.5 saying starting from left (x=0) to right (x=35.00), and the bearing supports are located at x=0 and x=35, the shaft configuration is 0<=x<=4.50" Ø=3.938", 4.50<=x<=31.5 Ø=4.438", 31.5<=x<=35 Ø=3.938", where W=11,036 lbs. at x=20.50". Thus for case 3: a=14.5, b=20.5, I=19.042, l=35.
I agree v=18.391574, so for a uniform shaft Ø of 4.438" the deflection I determined was 0.01659. I got TK Solver 4 here at work and will install it. I haven't used it since school years ago, so I will have to freshen up on it. I guess I can set up a program to solve a stepped shaft. Has any on already set up a program?
Cockroach, do you have Comos set up in conjunction with your Solidworks. We have here Inventor 7, haven't installed 8 yet. I doubt that Inventor can calculate deflection of a stepped shaft, I will probably need Comos or something similar installed with it.
