paulratledge
- Sep 29, 2011
- 13
I would really love an equation to figure out the deflection of a rotating shaft.
The shaft is 76" from bearing to bearing.
9" at 2.950" diameter
64" at 9.685" d
9.5" at 2.95" d
the 64"section is a hollow shaft and has about 52" at 3"d missing from middle.
density of material is .28lb/in^3 and we spin it at about 3000rpm.
there is no 'load' so to speak of on the object besides the weight of the object its self which if you calculate the volume and density is about 880lbs.
criticals would also be lovely. thank you
64" at 9.685" d
9.5" at 2.95" d
