JLNJ
- Oct 26, 2006
- 1,986
When using Factory Mutual or NFPA data sheets to determine pressures caused by combustible dusts, are those resulting pressures service or ultimate loads?
It makes sense to me that these would be ultimate loads (which can be used with the ASCE extraordinary even load combinations of 7-16 Section 2.5); however, I don't see in FM or the NFPA where they explicitly indicate one way or the other.
Some of these calculations remain unchanged from many years ago, so they might be borne of a service load tradition.
