I need to perform some tests for determining the chemical match between a certain filler metal (stick welding electrodes) and a base material.
This standard prescribes, as a very first test, a "single bead test", which is essentially a single bead on the base metal, in order to check visually and with dye penetrant.
The standard mentions: The welded bead shall be maximum electrode recovery using the manufacturer's parameters.
English is not my native language, so could someone please elaborate what they mean with this?
Is it the maximum length of a welded bead, done with a single electrode?
Has it got to do with stringer beads or weaving? The current with which we will be welding? Anything else?
I do understand recovery, but not in this context/phrase.
Thanks in advance...
