I'm not sure why this isn't in the Siemens 400-page user's guide. No instructions or rules about defining new materials for the materials library ESP file.
If someone can point me to a comprehensive guide to material definitions in FEMAP, then I could figure this out for myself.
My specific question is about units. Why do I sometimes see examples in ksi, MPa, psi, Pa? Does that imply that those users define their loads in kip, MN, lb, N, respectively?
Seeing "kilo" and "mega" and "milli" prefixes still doesn't seem consistent with the oft-repeated message that FEMAP is unitless.
No obvious method so "Save as..." The only offering is "save over top of the existing file"
The "Copy..." button allows me to create a new property from an existing one, but nonsensical values are pre-populated when I do this.
What values are optional for linear analysis with static loads and no variations in temperature?
Isn't the failure theory (Hill etc.) defined here? Can't find it. I've seen that check-box somewhere in FEMAP.
STF
STF
