M
maurya
Guest
When we create cross-sections in PART/ASSEMBLY mode,we can tell Pro/E to assign our own values for SPACING & ANGLE. Follow the techinque as described below.
Create the below mentioned two parameters (of type Integer or Real Number) with values of your liking in your START PART/START ASSEMBLY or in the PART/ASSEMBLY you are using as default template.
DEFAULT_XHATCH_SPACING
DEFAULT_XHATCH_ANGLE
Dwaraka N Reddy.Manchuri,RANN VISION,Hyderabad,India.
