D
Dan10
Guest
I am very frustrated with toleranced dimensions. When I change the number of decimal places on a dimension that has a tolerance the tolerance defaults back to the basic tolerance. For an example I have a dimension that is 5.0 +0/-3.0 and I want to change it to zero decimal places the tolerance changes to +.1/-.1. Why doesn't it change to +0/-3? Is there a setting to correct this problem?
