I am working on the application of an air operated Pacer centrifugal pump for a pumping application. I believe the flow rates we will get using it in our system will be too high. Would the best way to decrease flow rate is to add a Pressure Reducing Valve on the discharge side? Any other methods? Is the PRV is correct sizing would be:
1. Calculate discharge head without PRV.
2. Calculate difference of discharge head needed for the correct flow rate on the curve minus the rate you will get in your system.
3. Find K needed to get pressure drop as high as on the pump curve.
3. Calculate Cv for the pressure reducing valve using Crane manual.
Any other thoughts? Orfice in pipe? Throatting discharge gate valve?
