chairmantom
I have a TTL pulse from a camera which I want to use to trigger a laser off. The problem I have is that the signal from the camera is 1kHz, and I only want to trigger the laser at a frequency of 1Hz. So basically I need a device that takes the 1kHz signal and outputs a 1Hz signal (which is in step with the 1kHz input).
Any advice on a divice Which could do this would be most appreciated.
Tom
