We use 100Cr6 quenched and tempered steel from two different suppliers. The steel is quenched in oil (60°C) and tempered for 1.5h at 165°C. The working temperature of these components can be up to 170°C continuously. The component needs to have a certain hardness and stable dimensions.
We did a test: we put the components in a furnace at 170°C for 100hours. After that we measured the hardness and dimensions.
For the first supplier we see that the dimensions have increased (appr. 0.03mm), but with hardly any decrease of hardness.
The second supplier shows a decrease in hardness (appr. 4HRC), but with a less increase in dimensions (appr. 0.01mm).
How could the difference between the two suppliers be explained? Is there an inverse relation between changes in dimensions and hardness?
Does the content of the retained austenite may be of influence? How can these changes be eliminated?
