vonsteimel
Greetings,
Wanted to see what the opinions were on a couple frequently debated topics here at my workplace.
1. Decimals. Decimal equivelants of fractions are often used on engineering drawings. When you get a drawing that says cut to drill a hole at 0.19. Will you drill it at 0.19 or 0.1875?
2. Do you know all your fractions down to the 1/16ths? both 2 & 3 place decimals?
3. Would it be any simpler if drawings were given to you in fractions rather than decimals?
4. Do you scribe locations using caliper jaws or measure and use an actual scribe when working with soft steel or aluminum?
5. Do you do much locating/scribing using tape measure?
Any input will be greatly appreciated!
Thanks,
VS
Thanks,
VS
