Hi Friends,
Im my attempt to plot an involute spline, I am using the attached LSP.
The LSP program renders following error for both metric and inch based inputs.
Can anyone please tell me what may be the issue.
Command: gspline
Number of Teeth:<24> 24
Module or Diametral Pitch:<1.00> 1.0
Pressure Angle:<30.0> 30
Dedendum:<0.4800> 1.9
Addendum:<0.4000> 1.65
Arc Tooth Space :<1.5708> 1.66
CIRCLE Specify center point for circle or [3P/2P/Ttr (tan tan radius)]:
Specify radius of circle or [Diameter] <0.6495>: 12.00000000000000
Command: CIRCLE Specify center point for circle or [3P/2P/Ttr (tan tan radius)]:
Specify radius of circle or [Diameter] <12.0000>: 10.39230484541326
Specify radius of circle or [Diameter] <10.3923>: 10.35000000000000
Command: ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window] <real time>: w
Specify first corner: Specify opposite corner:
Command: PLINE
Specify start point:
Current line-width is 0.0000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
Command: ; error: bad argument type: numberp: nil
Command: gspline
Command: ZOOM
Command: PLINE
