So, if I am interpreting the view correctly, the truss structure is perpendicular to the rigid plane, right? I am also interpreting that the lowest row of GRID points in the view are all in contact with the rigid plane. Now you apply some loads somewhere which tend to cause the truss structure to slide across the plane, and you want to know if, and where, the structure fails (exceeds some nominal load value - hence the fuse).
If this interpretation is correct, what pushes the truss structure into contact - in other words, what sort of load develops the loads normal to the plane from which friction forces will emanate? Gravity, some press type loading?
DG
