We have a DC motor (Nameplate: GE Kinamatic DC Motor, 20 Hp, 1750 rpm, 240 volts, Shunt Wound, Field volts 150, type CD366AT, TENV) and an old controller of unknown origin with no documentation found as of yet - likely a one-off custom. The load is a much larger motor (~100 times DC motor rated Hp) with no other connections that will be coupled via a reduction gear/belt. We need to drive the load motor at rated speed (about 5 times less than the DC motor rated speed) in order to get BEMF data and perform other tests. It is anticipated that the load motor will need relatively high starting torque to get it spinning due to bearing friction and high inertia.
In looking at the DC motor terminal box, I assume it is separately excited since there are both field and armature winding leads and the nameplate gives different voltages for them. What is the maximum breakaway (starting) torque this type of motor can provide? Assuming we cannot operate the motor from the controller, what is the best way to control motor speed below base speed? We have a 150 vdc, 7 amp power supply that could be used for the field winding and a 3 phase fully controlled SCR based rectifier that could be used for the armature winding. If we apply rated field voltage and vary the armature voltage, will this provide good speed control below base speed and high starting torque? Could the field voltage then be used as a fine speed adjustment? Any suggestions would be appreciated. Thanks.
