I’m in search of a simple answer to a complex issue – an expression of the transfer function that describes conversion of amps to torque in a DC motor.
As background information, I am comparing the performance of two types of 1-HP DC motors that operate at a nominal 24 VDC. The wound field motor was previously used and had two very desirable properties in this particular application. First, torque produced is at a maximum when the load is heaviest. The mechanism driven by this motor may be obstructed in its normal course of operation and a mechanical clutch protects the motor and mechanism by limiting both torque and current. Secondly, the WF motor’s RPM is relatively high when the mechanism lightly loaded. This allows the machine to complete its operating cycle in the shortest possible time.
Manufacturing cost prompted adoption of PM motors 20+ years ago. The PM motor has proven itself capable of doing the job, but not with the same efficiency as its WF predecessor. To develop the necessary low-speed torque, current fed to the PM motor must be increased (i.e. terminal voltage must be raised). Another drawback of the PM motor is its lower peak RPM when lightly loaded. The machine’s cycle time increases by a noticeable amount of time when a PM motor is substituted for its WF predecessor.
What is the proper term for expressing the performance of a motor in converting amps to torque? Going one step further, how would this figure be evaluated against differing speed-torque curves? Is there a figure of merit that can be developed to compare these qualities against the baseline established by the original WF motor?
