haggisbasher
Hi all,
I'm using a DC-DC to drive a logic circuit from 12V, trouble is I need to make the ground of both the logic and power circuit common as they interface and power the same unit, this unit runs off of the 12V that I use to feed the DC-DC but the logic circuit also drives parts of this unit hence the ground connections needing to be common between logic and power.
Any help or ideas appreciated.
DC-DC is traco power 9-36VDC I/P; +/- 5VDC O/P.
Andrew
Andrew
