A
AlbertoMacias
Guest
When I select CL DATA > POST PROCESS and then select the .ncl file, I get this error message:
Windows cannot find "\i486_nt\obj\dblist.exe". Make sure you typed the name correctly, and then try again. To search for a file, clisk the Start button, and then click search.
Also, behind the error message, there is a system window with this error:
"i486_nt_ptc_setvars is not recognized as an internal or external command, operable program or batch file. Could not find C:\Automatizacion\maquinado\ptc_setvars.bat"
My working directory is C:\Automatizacion\maquinado. I set the gpostpp_dir option to C:\PTC\Wildfire 2.0\i486_nt\gpost. In this directory resides the UNCL01.pxx and UNCX01.fxx files. Also the proncpost_dbf option is set to "C:\PTC\Wildfire 2.0\i486_nt\obj" where the dblist.exe file resides.
It will be great if someone could help me with this.
Thank you
Thank you
