There are many experienced members and I would like to receive their comments regarding the DBB valve selection which is not very clear anywhere.
In my work, I located that the types of DBB valves are as follows
1.DBB Ball Vales (consisting of 2 valves)
2.Twin DBB Plug Valves (consisting of - 2 stems 2 plugs)
3.DBB Plug Valves
4.Through Conduit Slab Gate Valve
5.Through Conduit Expanding Gate Valve
6.Trunnion mounted ball valves with bleeding
7.Any other?
I understand that for real critical and high pressure applications and sealing must be granted, 1 and 2 is the best way. Pricewise, probably 2nd will be cheaper.
I read that 3,4,5 may not be providing good tighness.
I would be glad if you could share your comments
1.When you prefer 1 and 2?
2.I believe 1st option has limited sizes.
3.When could 3-4-5 be preferred?
4.Could anyone compare the prices of 1-2-3-4-5?
rgds to all
3.DBB Plug Valves
7.Any other?
rgds to all
