Hi I'm trying to clean up Gtol prints for different engineers but I don't recommend changes until I have confirmed that the changes I recommend follow standard. I couldn't find this in the book specialty
Ok I have an assembly situation
this is what Eng1 has listed
two bushings space 24plus inches apart welded in place (Intended to be coaxial). the left bushing is Dia x.xxx position .xxx mmc A, creating Datum -A1- (attached to feature frame). Right bushing is Dia x.xxx position .xxx mmc A creating Datum -A2- (attached to feature frame). he then uses these two bushings as Datum -A- in other feature frames.
From my understanding the left side should be dia x.xxx creating datum -A- and right side should be dia x.xxx position .xxx mmc A, creating datum -B- and all future feature frames should call out A-B to establish the two bushing as a datum.
my assumption is Eng1 is trying to use the datum target concept A1, A2, Etc using the datum flag to create a datum thru the two bushings. I believe this is incorrect application. plus he is referencing the datum to itself
Let me know if I'm off on this
